Текущее время: Ср 18 ноя 2026 06:34
СообщениеДобавлено: Вс 24 янв 2010 17:34
конфигурация kpc 3+
disp
8BITCONV ON
ABAUD 9600
AUTOLF ON
AX25L2V2 ON
AXDELAY 0
AXHANG 0
BEACON EVERY 10 (enabled)
BKONDEL ON
BLT 1 EVERY 00:30:00 START 00:00:00
BLT 2 EVERY 00:30:00 START 00:10:00
BLT 3 EVERY 01:00:00 START 00:20:00
BLT 4 EVERY 01:00:00 START 00:30:00
BREAK OFF
BTEXT
BUDLIST OFF NONE
A Link state is: DISCONNECTED
CANLINE $18 (CTRL-X)
CANPAC $19 (CTRL-Y)
CD SOFTWARE
CHECK 0 (disabled)
CMDTIME 1 (1 sec)
CMSG OFF
COMMAND $03 (CTRL-C)
CONLIST OFF NONE
CONMODE CONVERS
CONOK OFF
CONPERM OFF
CPACTIME OFF
CR ON
CRSUP OFF
CSTAMP OFF
CTEXT BEACON UA1CRX
CTRL A OFF B OFF
CWID EVERY 0 (disabled)
CWIDTEXT DE UA1CRX
DAYTIME 02/22/2009 22:17:55
DAYTWEAK 8
DAYSTR mm/dd/yyyy hh:mm:ss
DAMA OFF
DAMACHCK 18 (180 sec)
DBLDISC OFF
DELETE $08 (CTRL-H)
DIGIPEAT ON
DWAIT 0
ECHO ON
ESCAPE OFF
FLOW ON
FILTER OFF
FRACK 4 (4 sec)
FULLDUP OFF
GPSHEAD
1 $GPGGA
2
3
4
GPSINIT ?
GPSPORT 0 NORMAL CHECKSUM
GPSTIME VALID RMC
HBAUD 1200
HEADERLN ON
HID ON
HTEXT
INTFACE TERMINAL
KNTIMER 15 min
LEDS ON
LCOK ON
LFADD OFF
LFSUP OFF
LGETCHAR $05 (CTRL-E)
LLIST OFF NONE
LT
1 =6021.32N/02945.45E#DIGI Kivenapa.ru
2
3
4
LTP
1 APRS VIA WIDE2-2
2 APRS
3 APRS
4 APRS
LTRACK 0
MONITOR ON
MALL ON
MAXFRAME 4
MAXUSERS 10
MBEACON ON
MCON OFF
MCOM ON
MHEADER ON
MRESP ON
MRPT ON
MSTAMP OFF
MXMIT ON
MYCALL UA1CRX-3
MYALIAS WIDE
MYDGPS disabled
MYDROP 0
MYNODE UA1CRX-7
MYPBBS UA1CRX-1
MYREMOTE disabled
NDWILD OFF
NEWMODE ON
NETCALL disabled
NETALIAS
NETBUFFS 32
NETCIRCS 5
NETDESTS 25
NETLINKS 10
NETROUTE 5
NETUSERS 5
NOMODE OFF
NTEXT
NUMNODES 0
PACLEN 250
PACTIME AFTER 10 (1000 msec)
PASS $16 (CTRL-V)
PASSALL OFF
PBBS 100
PBFORWRD NONE EVERY 0 (disabled)
PBHEADER ON
PBHOLD ON
PBKILLFW OFF
PBLIST OFF NONE
PBLO NEW VARIABLE
PBMAIL OFF
PBPERSON OFF
PBREVERS ON
PBSIZE 0
PBUSERS 1
PERSIST 63 (25%)
PID OFF
PMODE CMD
PTEXT
RANGE 0-255/0-255/0-255/0-255/0-255
REDISPLA $12 (CTRL-R)
RELINK OFF
RETRY 10
RING ON
RNRTIME 0 (disabled)
RTEXT ?
SCREENL 0
SENDPAC $0D (CTRL-M)
SLOTTIME 10 (100 msec)
START $11 (CTRL-Q)
STOP $13 (CTRL-S)
STREAMSW $7C (|)
STREAMCA OFF
STREAMEV OFF
SUPLIST OFF NONE
SWP 17,17,108
TELEMTRY 0
TRACE OFF
TRFLOW OFF
TRIES 10
TXDELAY 30 (300 msec)
TXFLOW OFF
UNPROTO APRS
UIDIGI ON RELAY,WIDE1-1,WIDE2-2
UIDUPE 0 (disabled)
UIDWAIT OFF
UIFLOOD WIDE,30,NOID
UISSID ON
UITRACE TRACE,30
USERS 1
XFLOW ON
XKCHKSUM OFF
XKPOLLED OFF
XMITLVL 100
XMITOK ON
XOFF $13 (CTRL-S)
XON $11 (CTRL-Q)
cmd:
____________
Последний раз редактировалось RA1AMX Вт 26 янв 2010 23:20, всего редактировалось 1 раз.
СообщениеДобавлено: Пн 25 янв 2010 16:09
RD1AS (13:32:08 25/01/2010)
LTP 1 APRS
RD1AS (13:33:04 25/01/2010)
LTP
1 APRS VIA WIDE2-2
2 APRS
3 APRS
4 APRS
RD1AS (13:35:11 25/01/2010)
lt
ltp
blt
Алексей из автомобиля:
Последний раз редактировалось RA1AMX Вт 26 янв 2010 22:54, всего редактировалось 3 раз(а).
СообщениеДобавлено: Вт 26 янв 2010 22:43
Технические изменения в комплектации.
Получена моторола300 и блок питания.
Готовится постоянная антенна и мачта.
Контроллер сконфигурирован и работает:
2010-01-26 18:14:40 UTC: UA1CRX-3>ID,qAR,RA1AMW:UA1CRX-3/R UA1CRX-1/B
2010-01-26 18:19:00 UTC: UA1CRX-3>BEACON,qAR,RA1AMW:=6021.32N/02945.45E#DigiPeater Kivennapa
2010-01-26 18:20:00 UTC: UA1CRX-3>BEACON,qAR,RA1AMW:=6021.32N/02945.45E#DigiPeater Kivennapa
2010-01-26 18:20:27 UTC: UA1CRX-3>ID,qAR,RA1AMW:UA1CRX-3/R UA1CRX-1/B
2010-01-26 18:31:46 UTC: UA1CRX-3>BEACON,qAR,RA1AMW:=6021.32N/02945.45E#DigiPeater Kivennapa /PHG5000
2010-01-26 18:32:21 UTC: UA1CRX-3>ID,qAR,RA1AMW:UA1CRX-3/R UA1CRX-1/B
2010-01-26 18:33:03 UTC: UA1CRX-3>APRS,WIDE2-2,qAR,RA1AMW:=6021.32N/02945.45E#NEW DIGI KIVENNAPA[/img]
 Заголовок сообщения: мини-сервер WX
СообщениеДобавлено: Пт 19 фев 2010 22:30
мини-сервер WX
СообщениеДобавлено: Чт 25 фев 2010 15:51
порядок ввода команд для KPC 3+ и KPC 3 если вы хотите свой диги
ECHO ON
CD SOFTWARE
CTEXT BEACON UA1CRX
DIGIPEAT ON
FLOW ON
FILTER OFF
LT
LTP
1 APRS VIA WIDE2-2
2 APRS
3 APRS
4 APRS
MONITOR ON
MBEACON ON
MYCALL UA1CRX-3
MYALIAS WIDE
MYNODE UA1CRX-7
MYPBBS UA1CRX-1
TXDELAY 40
UNPROTO APRS
UIDUPE 0 (disabled)
UIDWAIT OFF
UISSID ON
UITRACE TRACE,30
USERS 1
XMITLVL 100 (здесть поиграйся значением, у меня на моторолу стоит 399 кажется)
СообщениеДобавлено: Чт 25 фев 2010 17:49
(Ошибки) Ненужные строки:
- абсолютно ненужны в твоём случае, и должны выглядеть по умолчанию:
BLT 2 EVERY 00:00:00
BLT 3 EVERY 00:00:00
BLT 4 EVERY 00:00:00
хотя если LT 2 - LT4 пустые, то BLT2-BLT4 игнорируются. Но процессор всёравно будет каждый раз проверять (ненужное действие).
СообщениеДобавлено: Ср 03 мар 2010 14:06
Важный параметр DWAIT, устанавливается для задержки, чтобы например не одновременно с соседними дигипитерами ваш дигипитер включился, а через интервал...
СообщениеДобавлено: Сб 03 апр 2010 00:13
временно приостановлена работа дигипитера по техническим причинам - питание и ожидание мачты ...
СообщениеДобавлено: Сб 03 апр 2010 09:34
Только не забываем в параметре UIDWAIT ставить ON а то первая команда
не будет выполняться и диджик будет ретранслировать без задержки.
СообщениеДобавлено: Сб 10 апр 2010 23:04
Сегодня распивая чай в новом месте в пределах локатора для установки дигипитера работал на КВ, провел порядка 10 QSO, отвечали с первого раза. на солнышке было +22, в тени +7.
ВОт мой недостроенный QTH 8)
снег еще лежит местами, вспомнилась бурная молодость Изображение
