вот исходники вроде бы
http://www.kh-gps.de/minitnc48.asmhttp://www.crosscountrywireless.net/Mod ... C%20V2.asm
SOFTWARE SETUP
;The temperature is read by the software and inserted in the beacon text at defined by metacharacters
;that you insert in the beacon text. The '\' is used to insert a metacharacter.
; The following are available \t (current temp),\a (current temp formatted for APRS weather message),
;\l (low temp), \h (high temp), and \s (sequence number). Thus using these characters you can format
;the temperature report to fit your needs.
; Note, the high and low temps are reset when the sequence rolls over at 99.
; Some Example
; btext Jefferson, NH temp is \t
; (gives the temperature at each beacon cycle)
; btext Jefferson, NH temp is \t, High \h, Low \l Sequence Number \s
; To get to the aprs you need a fixed number of chars, so \a is used.
; !4424.17N/07126.40W_.......t\a
; Sends your temperature data to APRS where you can view a graph of your temperature over time
; Note that you can output the temperature in either C or F using the temp command (temp C or temp F).
; Centigrade is slightly more accurate since the 18S20 outputs in C. There is a +/- error in F due to
;conversion roundoffs.
