dfg-870
Заголовок сообщения: Хороший, плохой, злой... Добавлено: Чт 24 сен 2009 01:08 |
R1ADA
Заголовок сообщения: Добавлено: Чт 24 сен 2009 09:26 |
Уменя ссылка не загрузилась.
Заголовок сообщения: Добавлено: Чт 24 сен 2009 10:38 |
Зарегистрирован: Сб 16 авг 2008 00:00 Сообщений: 4144 Откуда: Ligovo
dfg-870 то же самое. По запросу "good, bad and ugly operators" вышел на форум QRZ.COM:
Цитата: Since I have been a ham(1966) there has always been the good, bad, and ugly operators, and there will always be, so just because the FCC dropped the code requirements does mean it has gotten worse.
Hey you can always petition the FCC to require CW again
Get over it or get another hobby, life is just to short to worry about it.
K8YZK _________________ US Army Retired. (EX-WA8VBX,DA1UC,DA2VC,XW8GW,HL9JB)
olegatr
Заголовок сообщения: Добавлено: Чт 24 сен 2009 10:47 |
| Заслуженный баламут |
Вам конкретно делать нечего.
dfg-870
Заголовок сообщения: Добавлено: Чт 24 сен 2009 16:53 |
The Good, The Bad, and the Ugly (operators)
Submitted by n0hi on Wed, 09/23/2009 - 19:23
The Glorioso DXpedition has taught us all a valuable lesson: being a good operator is a rare skill. I don't say this because I think I'm a good operator, rather, I say this because the massive pileups contain a lot of hams who are, frankly, awful operators. We don't make new hams pass a code test anymore, so the least we can do is make sure that we enforce proper operating techniques. I don't mean to enforce it during the pileups; we need to start much earlier. The easiest way to do this is to be a great operator, and eventually people will emulate it. When I was a new ham, I would listen to some of the operators at the big multi/multis on a run. I remember thinking how smooth those guys were and trying to copy them. I even used to take notes.
Here are some things that have been bothering me in the pileups lately. If you are a culprit, don't take offense, just realize there is a better way!
1. WAIT to give your call. DX'ing and contesting involve a great deal of listening. Wait until the station asks for calls, sends QRZ, or whatever. Then give your call only once or twice (if absolutely necessary). Don't try to drop your call in early; sometimes this will annoy the operator and he'll ignore you on purpose.
2. Give your full call. The practice of sending the last two letters is antiquated and confusing. Identify yourself with your full callsign. This also helps to gain call recognition
3. Don't get cute. Use real phonetics. November Zero Hotel India.
4. Be concise. Don't try to ragchew with the guy. My usual response is "Thanks, you're [rst] in Colorado. Good luck!" Trust me, he won't care what your name is, but give it if he's been asking or if he's been giving his.
5. DON'T BE A DX COP. Policing the pileup might just be the poorest operating technique at all. If someone is doing something wrong, don't say anything. Just sit there and try to work around it. If he's bothering you, he's probably bothering the DX, and the DX can handle it.
6. If the DX asks for North America, or Europe, or West Coast, or whatever, keep quiet unless you are in those places. Even if nobody else is responding! You must wait your turn, same as the rest of us. Likewise, if he calls for 0-land, and you have a 0-land call but are vacationing in New England, you still can't call him yet!
7. Learn how to work split. It is an art in certain situations, and with the DX up to 200 on 40 meters now, it is becoming increasingly difficult to practice. Find opportunities, figure out your radio, and it will pay off.
8. Don't call the DX again to let him know his signal has improved or gotten worse. You already worked him, let everyone else have a chance.
9. Use proper cluster etiquette. Don't use it as a public chatroom or as a soapbox. Don't make comments about the operator. Don't ask QSL routing questions unless it is absolutely necessary. Finally, don't bicker...it doesn't do anyone any good.
10. Resist the urge to overprocess your audio, overdrive your amplifier, and overcrapify your signal. Believe it or not, there is still honor in having a clean, well-engineered signal. It doesn't take a big fancy equalizer, just the knowledge to drive your amplifier with the right amount of power, use a good microphone and element (we use Heil prosets with HC-4's here), and adjust your compression only as much as is needed.
11. Don't get frustrated. You'll work him eventually, and if you don't, it isn't the end of the world. Don't take out your frustrations on the rest of the radio community!
There are many, many tips and tricks to being a good operator. I couldn't list them all here, but you can find them available online, or simply by listening. We all can clean up the bands by making a concerted effort. Good luck and happy DX!
dfg-870
Заголовок сообщения: Добавлено: Чт 24 сен 2009 16:54 |
olegatr, это вам, умудрённым опытом с перегруженными диексами аппаратными журналами делать нечего, а мы учимсо.
UA1AFM
Заголовок сообщения: Добавлено: Чт 24 сен 2009 16:55 |
Вообще-то, это русскоязычный ресурс..
Может, потрудитесь перевести?
dfg-870
Заголовок сообщения: Добавлено: Чт 24 сен 2009 17:32 |
Нелогично.
Диексы ведь говорят по английски. Поэтому тот кто общается с диексами по умолчанию должен знать английский. Остальным это не надо.
ВРоде как то так?
UA1AFM
Заголовок сообщения: Добавлено: Чт 24 сен 2009 17:38 |
Не совсем. Радиолюбитель должен знать английский в объемах, минимально необходимых для проведения QSO.
А тут просто "Война и мир"...
dfg-870
Заголовок сообщения: Добавлено: Пт 25 сен 2009 00:28 |
DX экспедиция Glorioso дала нам очень ценный урок – быть хорошим оператором – это редкое умение. Я говорю это не потому что я считаю себя хорошим оператором, а потому что на тесных пайлапах слишком много ужасающего качества хамов. Мы отказались от экзаменов на морзянку для новых операторов, однако мы обязаны по крайней мере научить их адекватной операторской работе в эфире. Я не имею ввиду обучение непосредственно в пайлапах – мы должны начинать гораздо раньше. Лучший способ научиться работе в эфире – это подражание мастерам. Когда я был новичком, я помню как наблюдал за работой операторов на больших мульти/мульти станциях Я помню ощущение легкости их работы.. я даже делал записи в блокнотике.
Вот несколько вещей, которые раздражали меня в последнее время в пайлапах. Если вы узнаете в них себя – не обижайтесь, просто поймите, что можно работать лучше!
1. НЕ ТОРОПИТЕСЬ давать свой позывной. И в диексинге и в контестинге всегда есть место для наблюдения и прослушивания эфира. Подождите пока диекс просит его вызывать, дает QRZ либо еще как то обозначает свой переход на прием. После того давайте свой позывной один или два раза (в случае абсолютной необходимости) Не торопитесь и не пытайтесь засветить свой позывной как можно раньше – иногда это раздражает диекса и он после этгого специально будет вас игнорировать..
2. Давайте позывной полностью. Практика когда даются последние две букввы позывного устарела и является запутывающей. Идентифицируйте себя полным позывным. Это также помогает распознавать позывной.
3. Не пытайтесь изобретать пятое колесо. Используйте реальную фонетику -. November Zero Hotel India.
4. Будте сознательными, не пытайтесь завязать разговор с оператором. Мой обычный ответ в таких случаях - "Thanks, you're [rst] in Colorado. Good luck!" Поверьте мне, ему плевать какое ваше имя. Давайте ваше имя только если он попросит сделать это или если он сам назвал свое имя..
5. НЕ ПЫТАЙТЕСЬ БЫТЬ ДИЕКС-КОПОМ. Полицизация пайлапа, возможно, является худшим что может делать оператор в эфир. Если кто то что то делает неправильно – не говорите ничего. Просто сидите и попытайтесь не замечать. Если он мешает вам, вероятно он мешает и диексу. Диекс в свою очередь может справиться с этим самостоятельно..
6. Если диекс дает направленный вызов – соблюдайте тишину до тех пор пока он не позовет ваш регион. Даже если никто не отвечает из того региона который назвал диекс – не отвечайте. Просто ждите своей очереди как делают это остальные коллеги.
7. Научитесь работать на разнесенных частотах. В некоторых ситуациях это искусство. И например на диапазоне 40 м с его диекс участком до 7200 практиковаться становится все труднее и труднее.. Ищите возможности совершенствоваться, изучайте свой аппарат – это окупится сторицей..
8. Никогда не зовите диекса второй раз чтобы например сообщит ему что его сигнал улучшился. Вы уже сработали с ним – дайте сработать другим..
9. Соблюдайте этикет в кластере. Не используйте его как чат. Не комментируйте операторов, не просите QSL ку если на это нет крайней необходимости. Не флеймите – от этого никому и ничего хорошего не будет..
10. Не переусердствуйте с процессингом вашего сигнала. Не перекачивайте усилитель не поганьте ваш сигнал. Верите или нет – этодо сих пор считается почетным иметь чистый и безупречный технически сигнал.. Для этого не надо иметь супер пупер эквалайзер – достаточно базисных знаний о правильном использовании усилителя, хороший микрофон, и разумное использование компрессии..
11. Не расстраивайтесь если сработать с диексом не получилось. Это не конец света. И ради Бога не выплдескивайте свое горе на остальную часть радиолюбительского сообщества.!
Есть еще масса трюков и хитростей для того чтобы быть хорошим оператором, и естественно обо всех них здесь не рассказать. Но их можно найти в сети, а лучше просто слушать и учиться.
Совместно мы сможем сделать эфир чище если приложим хоть какие то усилия. Удачи и много диексов!
olegatr
Заголовок сообщения: Добавлено: Пт 25 сен 2009 09:05 |
dfg-870 писал(а): ...2. Давайте позывной полностью. Практика когда даются последние две букввы позывного устарела и является запутывающей. Кто кроме автора этих строк думает так-же? dfg-870 писал(а): ..7. Научитесь работать на разнесенных частотах. Картофелеводы форева! Они даже понятия не имеют, что есть такое дело. dfg-870 писал(а): ...слишком много ужасающего качества хэмов. Мы отказались от экзаменов на морзянку для новых операторов, однако мы обязаны по крайней мере научить их адекватной операторской работе в эфире. Я не имею ввиду обучение непосредственно в пайлапах – мы должны начинать гораздо раньше. Лучший способ научиться работе в эфире – это подражание мастерам. Когда я был новичком, я помню как наблюдал за работой операторов на больших мульти/мульти станциях Я помню ощущение легкости их работы.. я даже делал записи в блокнотике.
Парадокс, но это, как правило, немолодые хэмы. В России адназначна! У вас на репитере иногда такого наслушаешься, что стыдно становиться при одной мысли о возможности выхода таких "деятелей" на КВ, да и на УКВ тоже, дальше фрунзенского района СПБ  .
RK1AA
Заголовок сообщения: Добавлено: Пт 25 сен 2009 10:52 |
Я извиняюсь за негатив, но ДиЭкс-педиция Глориозо (а также Дуся, Авес и пр.) дала только один урок - идите в ко всем чертям со своими DXCC, кластером и дэиксами. Мне такие дэиксы не_нуж_ны. Вечный зов на полдиапазона без преувеличения инересен только с Дюси, Авеса и т. п.
Из Питера, Токио или Баден-бадена лично мне - нет.
Хоть целиком позывной называть, хоть алфа-алфа.
90% зовут, просто НЕ СЛЫША дэикса. А зачем? В кластере написано где он работает, а если ответит, то на следующий день о том, что провел связь узнаешь из онлайн лога. А если не узнаешь, то будешь с кучкой таких же придурков весь день орать на весь кластер "где вчерашние логи, почему их не выложили в сеть" и т. п. И весь день продолжать тупо выдавать свои "новембер индиа зулу хотел" непонятным "ап"ом не то плюс три не то плюс 300.
А затем SASE + 3 бакса ДиЭксу, и еще мешочек золотых в DXCC/LOTW за проверку. Пошли они к чертям со своим гребаным бизнесом, превратившим диапазоны в помойку.
olegatr
Заголовок сообщения: Добавлено: Пт 25 сен 2009 10:57 |
RK1AA писал(а): ..90% зовут, просто НЕ СЛЫША дэикса.
Есть такое смешное мнение и у меня. Получается дураков на планете лет на двести наперёд припасено
RA1AMX
Заголовок сообщения: Добавлено: Вс 14 мар 2010 00:03 |
слушаешь порой на 145 и диву даешься ... "я вас прекрасненько принимаю на канале" ... так и хочется порой вставить... "на обводном?" ... но кролик был культурный, и о чем он подумал , никто не узнал
в эфире я с 1996 года, не опробовал только ЕМЕ и ТРОПО, получил свой позывной в 1997 году, раз в году летом работал RK1ZXN с коллективки всеми видами, модами на всех диаппазонах ... Пока что с 3й категорией ... но когда слышу от людей с 1й категорией слова "прекрасненько, ваш сигнальчик, кто в канале и т.д. ... ... .
UA1C
Заголовок сообщения: Добавлено: Пн 15 мар 2010 01:38 |
Зарегистрирован: Сб 02 фев 2008 01:00 Сообщений: 7595 Откуда: Санкт-Петербург
Ну, формально всё правильно - канал связи, а вот касаемо слэнга и вобще формата проведения QSO, то это слово пришло из СиБи в радиолюбительский мир.
Не придирайся, уже не перевоспитаешь взрослых мужиков.
_________________ Вадим
