Текущее время: Ср 05 авг 2026 04:00
 Заголовок сообщения: Частоты спутников.
СообщениеДобавлено: Пн 15 июн 2009 13:12
CubeSat-OSCAR 55
Mode U Telemetry: Operational
Downlink 437.4000 MHz AFSK 1200 BPS
Mode U TLM Beacon: Operational
Downlink 436.8375 MHz CW
CubeSat-OSCAR 56
Downlink 437.3850 MHz CW
Mode L/U Packet: Operational
Uplink: 1268.5000 MHz GMSK 9600 BPS
Downlink 437.5050 MHz GMSK 9600 BPS
CubeSat-OSCAR 57
Mode U Beacon: Operational
Downlink 436.8475 MHz CW
Downlink 437.4900 MHz AFSK 1200 BPS
 Заголовок сообщения: Активные спутники
СообщениеДобавлено: Ср 03 мар 2010 14:18
Report from IARU Region 1 Satellite Coordinator
Monday, 22 February 2010 12:32
Current active OSCAR satellites
There are currently 8 satellites carrying voice transponders:
AO7 – linear transponders
AO27 FM transponder
FO29 - linear transponder
SO50 FM transponder
AO51 FM transponders
VO52 – linear transponder
SO67 FM transponder – launched since my last report
HO68 – linear and FM transponders – launched since my last report
•The ISS has a number of different operational modes which are activated whenever possible on the 2 metres and 70cms bands.
СообщениеДобавлено: Ср 03 мар 2010 14:27
Рабочие FM-спутники:
AO-51
работает по РАСПИСАНИЮ, http://www.amsat.org/amsat-new/echo/CTNews.php
FM Repeater, V/U
Uplink: 145.920 MHz FM, PL tone 67Hz
Downlink: 435.300 MHz FM -+доплер
June 1 - June 21 10:40Z
FM Repeater, V/U
Uplink: 145.920 Mhz FM, PL 67Hz
Downlink: 435.300 Mhz FM
June 21 10:40Z - June 24 09:35Z
FM Repeater, V/S
Uplink: 145.880 Mhz FM
Downlinks: 2401.200 Mhz FM
June 24 09:35Z - June 27 06:40Z
Please observe the 1 QSO per repeater Field Day rule
FM Repeater, V/U
Downlink: 435.300 Mhz FM -+доплер
June 27 06:40 - June 27 22:00Z
FM Repeater, V/S
June 27 22:00Z - July 5
FM Repeater, V/U
SO-50
работает (проверить статус).
Uplink: 145.8500 MHz FM, PL 67.0 Hz.
Downlink 436.7950 MHz FM (436.8000 FM) -+доплер
Operaion:
1) Transmit on 145.850 MHz with a tone of 74.4 Hz to arm the 10 minute timer on board the spacecraft.
2) Now transmit on 145.850 MHz (FM Voice) using 67.0 Hz to PT the repeater on and off within the 10 Minute window.
3) Sending the 74.4 tone again within the 10 minute window will reset the 10 minute timer.
AO-27
Рабочий, включается-выключается при пролёте через экватор. Расписание:
http://www.ao27.org/AO27/listing.shtml
Uplink: 145.850
Downlink: 436.797
Другие спутники.
HO-68 (XW-1)
Работает по расписанию, www.camsat.cn.
Uplink: 145.8250 MHz FM, PL 67.0 Hz.
Downlink: 435.6750 MHz FM
SO67 - выключен. новости: http://www.amsatsa.org.za/ .
Uplink: 145.8750 MHz FM, PL 233.6 Hz.
Downlink 435.3450 MHz FM
73![/i]
 Заголовок сообщения: Re: Частоты спутников.
СообщениеДобавлено: Вт 18 авг 2015 16:51
Спутник Fox-1A будет запущен 27 августа 2015 года.
Код:
                  Uplink FM (67 Hz tone)        Downlink FM
Fox-1A            435.180 MHz                   145.980 MHz
http://www.amsat.org/?p=3689
http://www.amsat.org/?p=4391
Чувствительность приемника -120 dbm для SINAD 12 db, с АПЧ +-6 кГц.
Номинальная мощность передатчика 400 мВт.
В голосовом канале со спутника на "поднесущей" будет содержаться DUV-телеметрия (data under voice).
СообщениеДобавлено: Пт 28 авг 2015 22:35
Запуск ЧМ-спутника Fox-1A перенесён на 8 октября.
http://www.sworld.com.au/steven/space/usmil-man.txt
Код:
                  UNITED STATES MILITARY MANIFEST (28 Aug 2015)
USA      Date    Launch Vehicle       Payload
  -    21 Jan 15  Atlas V551 (AV-052)  MUOS 3 (SV-4)
260   25 Mar 15  Delta 371 IVM+(4,2)  GPS IIF-09 (SVN 71, NAVSTAR 69, Deneb)
261   20 May 15  Atlas V501 (AV-054)  AFSPC 5 (OTV-4, X-37B-2 F2), ULTRASat
                                       (ELaNa XI (LightSail A), AeroCube 8A/8B
                                       (IMPACT), BRICSat-P, ParkinsonSat-A
                                       (PSAT-A), USS Langley, GEARRS 2, OptiCube
                                       1/2/3)
262   15 Jul 15  Atlas V401 (AV-055)  GPS IIF-10 (SVN 72, NAVSTAR 70, Antares)
263   24 Jul 15  Delta 372 IVM+(5,4)U WGS SV-7
       31 Aug 15  Atlas V551 (AV-056)  MUOS 4 (SV-3)
#       8 Oct 15  Atlas V401 (AV-058)  NROL-55 (INTRUDER 11A/11B, GRACE), ELaNa
                                       XII (ARC 1, BisonSat, Fox 1A, LMRSTSat),
                                       SNaP 3 (ALICE/EDDIE/JIMI), AeroCube 5C,
                                       AeroCube 7A (OCSD A), PropCube 1,
                                       PropCube 3, SINOD-D 1, SINOD-D 3,
                                       PTecSat, ParkinsonSat-B (PSAT-B)
          Spr 15  SALVO F1             ?
#       Change since beginning of month
СообщениеДобавлено: Вт 27 окт 2015 10:28
Вопрос закрыт. Частоты радиолюбительских спутников в одном файле XLS
http://www.ne.jp/asahi/hamradio/je9pel/satslist.htm
Latest Update by JE9PEL
СообщениеДобавлено: Вт 27 окт 2015 17:07
Я бы сказал не закрыт, а завален мусором.
1. 98% информации давно не актуально.
2. К знанию частот полезно знать когда его слушать и как через него работать. Учитывая то, что геостационарных среди них нет, а время пролета обычно около 3-10 мин, 1-5 раз в сутки, и работа очень многих осуществляется по расписанию.
Реально доступных для какого-либо использования из всей таблицы дай бог с дюжину наберется.
СообщениеДобавлено: Вт 27 окт 2015 17:14
Актуальные спутники нужно смотреть тут: http://www.amsat.org/status/
СообщениеДобавлено: Ср 28 окт 2015 14:12
Первое. Что понимается под словом "доступны" ? Много последних запущенных спутников работают в режимах AFSK 9600, PSK 1200. МКС тоже в режиме APRS/PACKET 1200. Можно сказать, что они недоступны, потому что сложно принимать/декодировать? Тогда в категорию "мусор" нужно записать 98% спутников.
Второе: радиолюбительская нагрузка, как правило, второстепенная. Первоочередное занятие - эксперименты / исследования для институтов.
Поэтому, согласен, чисто для CQ DX наберется до 10 спутников с линейными или ЧМ транспондерами. Но нужно учитывать, что для проведения SAT-связей всё равно потребуется достаточно продвинутый "сетап" (несколько антенн, МШУ, контроллер поворотки) и знание английского. Технологическая же информация снимается на более простые антенны, часто всенаправленные или типа "квадрафилярной" (лепесток ДН вверх). Поэтому, данный список JE9PEL/1 полезен.
Третье: геостационарный спутник для радиолюбителей не будет запущен никогда. Можно сетовать по этому поводу, но это факт. Проходы низкоорбитальных спутников примерно в одно и то же время суток, важно лишь рассчитать точное время.
