Текущее время: Ср 09 сен 2026 08:04
 Заголовок сообщения: Приемник Tecsun PL600
СообщениеДобавлено: Вт 10 июн 2008 22:45
Обзорное видео о приемнике
Ссылка:
http://au.truveo.com/Tecsun-PL600-demo-on-VHF/id/1043811489
SSB
http://au.truveo.com/my-new-Tecsun-PL600-SSB-portable-radio/id/589337847
l Worldwide coverage with FM stereo/SW/MW/LW/SSB reception
l FM frequency:76.0-108.0MHz,step 0.1MHz/0.01MHz
l AM frequency (incl. SW.MX.LW):100-29999KHz,step 9K/1K or 10K/1K
l Jog dial tuning/auto scan/memory scan/direct entry
l 600 memories presetting
l Memory permanently saved(except clock time)
l AM if wide/narrow selectivity
l Orange backlight, backlight mode selectivity
l AM signal strength indicator
l FM mono/stereo selectivity
l Tone select: news or music
l Two groups alarm ON/OFF
l 1-99 minutes sleep time setting
l Clock function
l Hold button
l SW meter band indication/conversion
l Battery level indicator, auto OFF with weak battery
l Extra-long telescopic antenna
l Local/DX switch
l External antenna jack
l Line out jack
l Use 4 AA batteries
l Accessories: stereo earphones, external antenna, AC adaptor, 4 NI-MH rechargeable batteries, carrying pouch
l Dimensions:188×116×31mm
l Weight:445g (excl. batteries) , 1.4kg - Including all attachment and package .
SPECIFICATIONS
① FREQUENCY RANGE
FM: 76MHz-108MHz
AM: 100KHz-29999KHz
SW: 1710KHz-29999KHz
120m:2.25MHz - 2.55MHz
90m:3.150MHz - 3.450MHz
75m:3.850MHz - 4.050MHz
60m:4.700MHz - 5.100MHz
49m: 5.800MHz - 6.300MHz
41m: 7.100MHz - 7.500MHz
31m: 9.400MHz - 10.000MHz
25m: 11.500MHz - 12.150MHz
22m: 13.500MHz - 13.900MHz
19m: 15.000MHz - 15.900MHz
16m: 17.450MHz - 18.000MHz
15m: 18850MHz - 19100MHz
13m: 21.450MHz - 21.950MHz
11m: 25.600MHz - 26.100MHz
② NOISE LIMIT SENSITIVITY
FM ≤ 3μV
MW ≤ 1mv/m
LW ≤ 1.2mv/m
SW ≤ 20μV
③ SW SELECTION:
5K ≥ 28dB 7K ≥ 45dB
④ POWER SUPPLY:
battery : 4 AA batteries
We are forbidden from sending batteries via CHINA POST since it is dangerous.
This is to do with country regulations. Therefore I have to hide it in the Soft carrying case (one of accessories of the radio).
AC adapt : Input 220V 50Hz Output 6V 300mA
Последний раз редактировалось RD1AS Вт 10 июн 2008 23:11, всего редактировалось 1 раз.
СообщениеДобавлено: Вт 10 июн 2008 23:06
Где Покупать?
СообщениеДобавлено: Вт 10 июн 2008 23:08
Из плюсов, в отличии от дегена есть ручной преселектор , но зато в дегене спошное перекрытие по частоте от 100 до 30000 а тут прием с пропусками .
СообщениеДобавлено: Вт 10 июн 2008 23:15
Видео дополнено,
По поводу сплошного диапазона...., может раскрывается.
СообщениеДобавлено: Вт 10 июн 2008 23:22
Купить можно тут http://www.1962.ru/index.php?productID=1027
А Деген раскрывается до 40000.
RA1ACO
SP_560
2:5030/518.90 FidoNet
СообщениеДобавлено: Вт 10 июн 2008 23:29
Вроде-бы здесь...
АУРА ЭЛЕКТРОНИКС
Садовая, Санкт-Петербург, Бринько пер., д. 3
т/ф. +7(812) 327-2121
СообщениеДобавлено: Вт 10 июн 2008 23:57
Вид цифровой
УКВ диапозон: 76-108MHz
ДВ диапозон: 100-519KHz
СВ диапозон: 520-1710KHz
КВ диапозон: 1711-29999KHz
Чувствительность FM- 3µV, MW- 1,0mv/m,LW-1.2mV/m, SW-20µV SSB +
Двойное преобразование частоты +
Память 600
Питание: 6V
Размеры 181x116x31mm
Радиоприемник Tecsun PL-600 построен по супергетеродинной схеме с синтезатором и двойным преобразованием частоты. Высокая чувствительность и возможность приема SSB и CW позволяют использовать PL-600 для наблюдения за работой любительских радиостанций на всех КВ диапазонах.
Вид цифровой
Память 600
Питание: 6V
Размеры 181x116x31mm Другие функции: часы/будильник/таймер отключения, 2 таймера включения Комплект поставки: приемник, чехол, БП 220В, 4 аккумулятора 1000 ма.ч., наушники, внешняя антенна, инструкция.
СообщениеДобавлено: Ср 11 июн 2008 00:32
Описание: http://img232.imageshack.us/img232/9717 ... 600jp6.jpg
СообщениеДобавлено: Ср 11 июн 2008 00:35
Можно почитать сдесь:
http://www.radioscanner.ru/forum/index. ... 587&page=0
СообщениеДобавлено: Ср 11 июн 2008 09:55
Где же вы такие переводы берете? :shock:
Почитал, оставляю свой Деген 1103 - старый друг, лучше новых....
СообщениеДобавлено: Чт 03 июл 2008 22:20
RA1ASC писал(а):
Из плюсов, в отличии от дегена есть ручной преселектор.... .
Что-то я не заметил его.
Даже кнопку сброс нашел, кот. спрятана.
СообщениеДобавлено: Ср 29 окт 2008 19:13
Здоровья всем! А я вот поменял свой DE1103 на PL-600... Замена однозначно в лучшую сторону. Если не планируете носить радио в брючном кармане - безусловно надо брать PL! Освободившийся DEGEN после сравнительного тест-драйва без сожаления отослал приятелю в Анапу... Там ТАКОЙ ХОД...! Пусть радуется на пляже. До этого аналогично избавился от YB-400. В свое время с радостью заменил его DEGENом.. На что и КОГДА будем менять PL-600?... 73!
За ДАЛЬНЕЙШЕЕ распространение радиоволн! (любимый тост)
СообщениеДобавлено: Пн 17 ноя 2008 17:55
Напиши поподробнее о своих впечатлениях по ТЛ-600 ...Как он - нормалёк ?
СообщениеДобавлено: Пн 29 дек 2008 15:05
Меняю на такой же ...НО! -
Не через 1962.RU. Заказал через знакомых в USA...
(на Е- BAY...)
Похоже 1962... левак какой-то реализовывали -
можжет монополистами были пол года назад... - на РАДИОСКАННЕРЕ
много негативных откликов + моя ЛИЧНАЯ НЕПРУХА....
Не хочу своей денежкой их "бизнес" поощрять...
НО аппарат весьма ДОСТОЙНЫЙ!...73!
