Текущее время: Вс 12 июл 2026 06:50
Начать новую тему Ответить на тему  [ Сообщений: 66 ]  На страницу 1, 2, 3, 4, 5  След.
 Заголовок сообщения: Необычные решения компактных КВ антенн
СообщениеДобавлено: Вт 22 июл 2008 16:18
Антенны Isotron
Обеспечивают характеристики сравнимые с диполем при оччень скромных габаритах. Привезу на пробу(не в ближайшее время) и позже выложу результаты собственных исследований. Кому хочется быстрее - заказывайте для себя.
Двадцатку
На сороковку.
Восьмидесятку
80+40
Как работает? Переводить лениво, читайте -
How Do The Isotrons Work So Well?
This is a very common question from those that have not seen the ISOTRONS in action. Even those that have, ask it with amazement.
Well, it's not magic. The ISOTRONS have been developed around specific electrical laws and laws of physics. At times, the eye can be deceived so that something may look like it is against known laws or what we know as practical.
For an antenna to work, it should be electrically resonant. The ISOTRONS are electrically resonant by using only two components - the large coil in series with the capacitive plates of the antennas. (Match comes automatically with the right combination of the two components at resonance).
There is more that is necessary for an efficient antenna. An antenna needs a certain amount of area to couple radiation to the atmosphere. Some call this the "Capture Area". However, this is an "AREA". This "area" can be any shape or form. The laws of physics for this phenomenon do not specify its appearance. THE ISOTRONS HAVE THIS RADIATION "AREA". The ISOTRONS exceed or equal (depending upon the model) the area of a conventional one-half wavelength dipole (#12 wire). In simple terms, we designed the ISOTRONS into a three dimensional package.
THE PERFORMANCE - It speaks for itself.
Tests have measured the ISOTRONS to transmit as well as a one-half wavelength dipole. The shape of the ISOTRONS give them an excellent advantage for the reduction of noise. The ISOTRONS have been tested at 3db less noise on reception with an equivalent incoming signal as the one-half wavelength dipole.
In the six antenna Reviews, one characteristic was definitely distinctive of the ISOTRONS: THE PERFORMANCE.
The ISOTRONS were developed around known laws to accomplish an efficient performing antenna in a very convenient package.
СообщениеДобавлено: Вт 22 июл 2008 16:38
Ммм....Присутствует скепсис про "Как работают?"...Нечто подобное рассказывают про так называемые "ЕН-антенны"....Спорить не буду.Хочется услышать мнение "нашего" человека - Олега, а не рекламу. {as_starp01} А сама тема Компактные КВ антенны очень интересна!
СообщениеДобавлено: Вт 22 июл 2008 16:44
Получите дорогой товарисч -
http://www.eham.net/reviews/detail/311
СообщениеДобавлено: Вт 22 июл 2008 16:55
Не получил!НаписАть можно все что угодно!Интересно ТВОЕ мнение после испытаний! :wink:
СообщениеДобавлено: Вт 22 июл 2008 17:06
Андрей, но eham.net это наше все. Кто попало и тем более рекламщики там не пишут. Надо уважать мнение коллег. ЕН антенны здесь, конечно, не обсуждаются...
СообщениеДобавлено: Вт 22 июл 2008 19:50
Уже слышал в R7, что кому-то такую антенку подарили. Но вопросы все-таки имеются. Насколько я понял из описания, то контура в антенне достаточно добротные, поэтому настройка в резонанс довольно-таки остарая, что является некоторым минусом. Второе - никто не говорит о какой-нибудь серьёзной работе данных антенн на передачу и максимальной подводимой к ним мощности. Во втором я сильно сомневаюсь, поскольку эффективность такой антенны на передачу будет стремиться к нулю.
Олег, если рискнёшь провести полноценный эксперимент, то дерзай, но я лично, даже после массы отзывов на хэмовских сайтах, всё-таки побаиваюсь покупать "кота в мешке".
СообщениеДобавлено: Вт 22 июл 2008 21:14
Я не боюсь. Мне просто очень интересно...
СообщениеДобавлено: Ср 23 июл 2008 11:21
Олег - вы что - серьёзно это обсуждаете ?
Соглашусь с Андреем - потратьте деньги
на это .... с позволения сказать...
- может потом поймете .
И уж тем более советовать это на сайте.
выраженные в сжатой форме.
73. Сергей.
СообщениеДобавлено: Ср 23 июл 2008 11:32
При всем уважении,не соглашусь с высказыванием!Наше хобби - путь испытаний и экспериментов разных устройств.Соответственно, с успехами и разочарованиями.В данном случае Олег ничего не советует ИМХО...Человек сам определит нужен ему такой девайс или нет.Просто есть возможность заказать,а дальше....."Каждый сам за себя!"(С) :wink:
P.S. Вот....Опять в сторону от темы... :oops:
СообщениеДобавлено: Ср 23 июл 2008 11:34
Сергей, это интересно, мне и многим товарищам с форума, которых я лично знаю. Я не впариваю Вам эти антенны, я делюсь информацией с коллегами. Что Вы там увидели между строк? Я потом все мойму, а сейчас мы просто обсуждаем сабж - это интересно... Давайте по существу - вы тестировали эти антенны конкретно?
СообщениеДобавлено: Чт 24 июл 2008 13:45
Я с детских лет усвоил простую истину.
Хорошая антенна - это полноразмерная антенна.
Ну если допустить,конечно, что есть инопланетяне а их
космические корабли находятся очень
далеко от своих галактик - а они общаются между собой.
Какие же у них антенны ?
Или есть какой то другой способ связи ?
А если серьёзно - загляните сюда - проволочные антенны для
ДХ-инга
http://forum.qrz.ru/thread13747-39.html
73. Сергей.
СообщениеДобавлено: Чт 24 июл 2008 18:06
Ведущий EchoLink
RZ9CJ
olegatr
Скажем так, какая э.д.с. наведется в неполноразмерной антенне?
Но если Олег желает, то пусть привезет, мне лично очень интересно будет взглянуть.
В детстве смотрел фильм "Москва - Кассиопея."
Без сознания лежала вся команда "Зари".
Шевельнулся Витька, приоткрыл глаза.
И вдруг ему показалось, что он находится в Музее Космонавтики в Калуге, а за столом, у доски с его формулами и чертежами сидят учёные.
- Я верю, что если не мы, то вы когда-нибудь научитесь прогрызать дырки в пространстве, - говорит Филатов.
Он ощупал себя.
- Жив, кажется, - прошептал он и взглянул на табло доплерометра. Стрелка по-прежнему дрожала за цифрой 300000.
(с) http://www.mielofon.ru/kinofan/otroki/otroki3_sc5.htm
Игорь
СообщениеДобавлено: Пн 28 июл 2008 00:12
Когда то говорили что человек не может летать.
СообщениеДобавлено: Пн 28 июл 2008 09:27
И правильно говорили.
Человек и до сегодняшнего дня не может летать.
Факт.
Летают самолеты и космические корабли.
Тоже факт.
73. Сергей.
СообщениеДобавлено: Ср 30 июл 2008 21:42
Основной плюсь такой антенны это согласование с передатчиком ,но посравнению с полноразмерной энтенной это не что , на сqhame и qrz
столько про них понаписали - развили даже особенную теорию распостранения радиоволн :)) http://www.qrz.ru/articles/detail.phtml?id=282
Такие антенны описаны еще у Ротхамеля но не у радиолюбителей не у военных развитие не получили , всплывающий интерес к таким штукам можно обьеснить легкостью изготовления (пара бытылок от пепсиколы ,моток проволоки и несколько жестянок :)))
Но к сожелению работают они только когда есть хорошее прохождение но в такие моменты связатся можно и на кусок провода
Олег найди лутче где продаются недорогие антенны анализаторы - народ оторвет с руками и пользы будет больше .
