RA1AMX
Заголовок сообщения: Re: Digi Пудость Добавлено: Вс 08 апр 2012 22:49 |
RA1AMO
Заголовок сообщения: Re: Digi Пудость Добавлено: Пн 09 апр 2012 15:51 |
| Зам. Рыжего Лиса |
Ваня, вот мой рабочий конфиг с KPC-3 Код: 8BITCONV ON AX25L2V2 ON ABAUD 9600 AUTOLF ON AXDELAY 0 AXHANG 0 BEACON EVERY 0 (disabled) BKONDEL ON BLT 1 EVERY 00:10:00 2 EVERY 00:00:00 3 EVERY 00:00:00 4 EVERY 00:00:00 BREAK OFF BTEXT BUDLIST OFF NONE A Link state is: DISCONNECTED CANLINE $18 (CTRL-X) CANPAC $19 (CTRL-Y) CD SOFTWARE CHECK 0 (disabled) CMDTIME 1 (1 sec) CMSG OFF COMMAND $03 (CTRL-C) CONLIST OFF NONE CONMODE CONVERS CONOK OFF CONPERM OFF CPACTIME OFF CR OFF CRSUP ON CSTAMP OFF CTEXT CWID EVERY 0 (disabled) CWIDTEXT RA1AMO KP40ON DAYTIME 05/06/00 03:53:34 DAYTWEAK 8 DAYSTR mm/dd/yy hh:mm:ss DAMA OFF DAMACHCK 18 (180 sec) DBLDISC OFF DELETE $08 (CTRL-H) DIGIPEAT ON DWAIT 250 (2500 msec) ECHO ON ESCAPE OFF FLOW ON FILTER OFF FRACK 4 (4 sec) FULLDUP OFF GPSHEAD 1 $GPGGA 2 3 4 GPSINIT HBAUD 1200 HEADERLN ON HID OFF HTEXT INTFACE TERMINAL KNTIMER 15 min LEDS ON LCOK ON LFADD OFF LFSUP OFF LLIST OFF NONE LT 1 =6034.58N/02911.60E#PHG5260 DIGI de RA1AMO@mail.ru 2 3 4 LTP 1 APN382 VIA WIDE1-1,WIDE2-2 2 APRS 3 APRS 4 APRS LTRACK 0
MONITOR ON MALL ON MAXFRAME 4 MAXUSERS 10 MBEACON OFF MCON OFF MCOM ON MHEADER ON MRESP ON MRPT ON MSTAMP OFF MXMIT ON MYCALL RA1AMO-3 MYALIAS RA1AMO MYDROP 0 MYNODE RA1AMO-3 MYPBBS RA1AMO-3 MYREMOTE disabled NDWILD OFF NEWMODE ON NOMODE OFF NTEXT NUCR 0 NULF 0 NUMNODES 0 PACLEN 0 PACTIME AFTER 10 (1000 msec) PARITY NONE PASS $16 (CTRL-V) PASSALL OFF PBBS 5 PBFORWRD NONE EVERY 0 (disabled) PBHEADER ON PBHOLD ON PBKILLFW OFF PBLIST OFF NONE PBLO NEW VARIABLE PBPERSON OFF PBREVERS ON PERSIST 64 (25%) PID OFF PMODE CMD PTEXT REDISPLA $12 (CTRL-R) RELINK OFF RETRY 10 RING OFF RNRTIME 0 (disabled) RTEXT ? SCREENL 0 SENDPAC $0D (CTRL-M) SLOTTIME 10 (100 msec) START $11 (CTRL-Q) STOP $13 (CTRL-S) STREAMSW $7C (|) STREAMCA OFF STREAMEV OFF SUPLIST OFF NONE SWP 17,17,108 TRACE OFF TRFLOW OFF TRIES 10 TXDELAY 40 (400 msec) TXFLOW OFF UNPROTO APRS UIDIGI ON APRS,WIDE2-2,WIDE1-1 UIDWAIT OFF UIFLOOD WIDE,30,ID UITRACE TRACE,30 USERS 1 XFLOW ON XKCHKSUM OFF XKPOLLED OFF XMITOK ON XOFF $13 (CTRL-S) XON $11 (CTRL-Q)
RA1AMX
Заголовок сообщения: Re: Digi Пудость Добавлено: Пн 09 апр 2012 21:19 |
Спасибо! Вобщем то мои догадки частично подтверждаются ... 1. часть настроек кантроникса не верные 2. моторолы плохие по чутью + закрытый шумоподавитель обрывает у них пакеты В общем то завтра попробую воткнуть на диджике alinco 195  Посмотримс ... Сегодня прописав вместо wide позывной диджика в общем то неплохо проходили пакеты   Как вариант улучшения связи - увеличение параметра aprs tx delay в vx-8 до 500, 750 или 1000 мс эффект на лицо - весь участок дороги от города до qth доступен на автомобильную антенну и 5 Вт  :
RA1AMW
Заголовок сообщения: Re: Digi Пудость Добавлено: Пн 09 апр 2012 23:23 |
| Рыжий Лис |
TX delay - значение задержки передачи данных для необходимых переходных процессов радиостанции при включении на передачу. Т.е. Параметр индивидуальный для радиостанции. Мне кажется что надо подбирать оптимальный параметр DWAIT. Но он должен быть определен у всех станций общей сети что бы не было коллизий при передаче.
RA1AMX
Заголовок сообщения: Re: Digi Пудость Добавлено: Вт 10 апр 2012 08:16 |
может с шагом 50 сделать? ...
RA1AMX
Заголовок сообщения: Re: Digi Пудость Добавлено: Вт 10 апр 2012 18:52 |
cmd:DISP 8BITCONV ON AX25L2V2 ON ABAUD 9600 AUTOLF ON AXDELAY 0 AXHANG 0 BEACON EVERY 0 (disabled) BKONDEL ON BLT 1 EVERY 00:10:00 2 EVERY 00:00:00 3 EVERY 00:00:00 4 EVERY 00:00:00 BREAK OFF BTEXT = BUDLIST OFF NONE A Link state is: DISCONNECTED CANLINE $18 (CTRL-X) CANPAC $19 (CTRL-Y) CD SOFTWARE CHECK 0 (disabled) CMDTIME 1 (1 sec) CMSG OFF COMMAND $03 (CTRL-C) CONLIST OFF NONE CONMODE CONVERS CONOK OFF CONPERM OFF CPACTIME OFF CR OFF CRSUP ON CSTAMP OFF CTEXT CWID EVERY 0 (disabled) CWIDTEXT DE GF DAYTIME 00/03/00 06:47:07 DAYTWEAK 8 DAYSTR mm/dd/yy hh:mm:ss DAMA OFF DAMACHCK 18 (180 sec) DBLDISC OFF DELETE $08 (CTRL-H) DIGIPEAT ON DWAIT 175 (1750 msec) ECHO ON ESCAPE OFF FLOW ON FILTER OFF FRACK 4 (4 sec) FULLDUP OFF GPSHEAD 1 $GPGGA 2 3 4 GPSINIT HBAUD 1200 HEADERLN ON HID OFF HTEXT INTFACE TERMINAL KNTIMER 15 min LEDS ON LCOK ON LFADD OFF LFSUP OFF LLIST OFF UA1CRX LT 1 =5936.69N/03002.92E#PHG5360 DIGI PUDOST 2 3 4 LTP 1 APN382 VIA WIDE1-1,WIDE2-2 2 APRS 3 APRS 4 APRS LTRACK 0
MONITOR OFF MALL ON MAXFRAME 4 MAXUSERS 10 MBEACON OFF MCON OFF MCOM ON MHEADER ON MRESP ON MRPT ON MSTAMP OFF MXMIT ON MYCALL UA1CRX-4 MYALIAS UA1CRX-15 MYDROP 0 MYNODE UA1CRX-4 MYPBBS UA1CRX-4 MYREMOTE NDWILD OFF NEWMODE ON NOMODE OFF NTEXT NUCR 0 NULF 0 NUMNODES 2 PACLEN 128 PACTIME AFTER 10 (1000 msec) PARITY NONE PASS $16 (CTRL-V) PASSALL OFF PBBS 5 PBFORWRD NONE EVERY 0 (disabled) PBHEADER ON PBHOLD ON PBKILLFW OFF PBLIST OFF NONE PBLO NEW VARIABLE PBPERSON OFF PBREVERS ON PERSIST 63 (25%) PID OFF PMODE CMD PTEXT REDISPLA $12 (CTRL-R) RELINK OFF RETRY 10 RING OFF RNRTIME 0 (disabled) RTEXT SCREENL 0 SENDPAC $0D (CTRL-M) SLOTTIME 10 (100 msec) START $11 (CTRL-Q) STOP $13 (CTRL-S) STREAMSW $7C (|) STREAMCA OFF STREAMEV OFF SUPLIST OFF NONE SWP 17,17,108 TRACE OFF TRFLOW OFF TRIES 10 TXDELAY 40 (400 msec) TXFLOW OFF UNPROTO APRS UIDIGI ON APRS,WIDE2-2,WIDE1-1 UIDWAIT OFF UIFLOOD WIDE,30,ID UITRACE TRACE,30 USERS 1 XFLOW ON XKCHKSUM OFF XKPOLLED OFF XMITOK ON XOFF $13 (CTRL-S) XON $11 (CTRL-Q) cmd:
RA1AMX
Заголовок сообщения: Re: Digi Пудость Добавлено: Сб 21 апр 2012 15:17 |
вот и соседей слышно  ES2ADF-1 1 2012-04-19 09:12:55 2012-04-19 09:12:55 KO29XG > KO59AO 234.3 km 262° 2012-04-19 09:12:55
RA1AMW
Заголовок сообщения: Re: Digi Пудость Добавлено: Пн 21 май 2012 09:21 |
| Рыжий Лис |
Вчерашний рекорд 411 km: OH6RDC 2012-05-20 05:19:19 GMT KP22VQ > KO59AO 411.3 km 328°
RA1AMW
Заголовок сообщения: Re: Digi Пудость Добавлено: Пт 03 авг 2012 14:11 |
| Рыжий Лис |
Иван, что с ДИГИ случилось? 10 км для 25 Вт, это вообще ни что! Вложение:
ua1crx-4.jpg [ 158.67 Кб | Просмотров: 11104 ]
RA1AMX
Заголовок сообщения: Re: Digi Пудость Добавлено: Пн 06 авг 2012 00:32 |
с диги все ок ищите у себя OH5NSV-9 1 2012-08-01 06:00:52 2012-08-01 06:00:52 KP41JE > KO59AO 186.8 km 339° 2012-08-01 06:00:52 RV1CJ-9 40 2012-08-03 05:25:32 2012-08-03 12:44:19 KO59DS > KO59AO 22.2 km 44° 2012-08-03 05:25:32 RD1AS-3 5 2012-08-01 08:27:11 2012-08-04 15:12:08 KO59EU > KO59AO 34.0 km 32° 2012-08-04 15:12:08 UA1CRX-3 94 2012-08-01 10:45:13 2012-08-05 22:14:47 KP40VI > KO59AO 83.9 km 349° 2012-08-05 22:14:47 RA1AMW-13 7 2012-08-01 08:39:18 2012-08-06 00:01:16 KP50DA > KO59AO 48.3 km 17° 2012-08-06 00:01:16 ES2ADF-1 3 2012-08-01 06:16:22 2012-08-05 10:01:40 KO29XG > KO59AO 234.3 km 262° 2012-08-05 10:01:40
RA1AMW
Заголовок сообщения: Re: Digi Пудость Добавлено: Пн 06 авг 2012 11:15 |
| Рыжий Лис |
Может действительно не Диги, а APRS.FI глючит. Я вчера прокатился по Карельскому перешейку, покрытия в скандинавском направлении нет.
RA1AMX
Заголовок сообщения: Re: Digi Пудость Добавлено: Пн 06 авг 2012 11:36 |
ага, но тебя видно, мою портативку видно ... вчера пиликала постоянно до ночи...
RA1AMW
Заголовок сообщения: Re: Digi Пудость Добавлено: Пн 06 авг 2012 11:41 |
| Рыжий Лис |
RA1AMX
Заголовок сообщения: Re: Digi Пудость Добавлено: Пн 06 авг 2012 11:48 |
Нет, у кого то частота плывет
RA1AMW
Заголовок сообщения: Re: Digi Пудость Добавлено: Пн 06 авг 2012 12:10 |
| Рыжий Лис |
Даже интересно у кого?
